Author Topic: vsdiff problems  (Read 5806 times)
redwards
Re: vsdiff problems
« Reply #15 on: October 03, 2014, 04:12:49 pm »
Can you zip up that config and send it to me?
I responded with the config, but not sure it made it.
Nonetheless, I reset my config and at least vsdiff is loading.
On another note, I see another problem that I don't know if you've handled, since it appears to be related to filenames.  Not sure if I should start a new topic or not.
The problem is that if I specify an FTP file, it crashes.  That is, a buffer that is an FTP connection (ftp://host/path).
  • Hero Points: 140
Re: vsdiff problems
« Reply #16 on: October 03, 2014, 05:16:44 pm »
Reproduced.  Not sure what is going on here.  Thanks for the report.
  • Hero Points: 140
Re: vsdiff problems
« Reply #17 on: October 09, 2014, 06:21:08 pm »
Fixed for the next drop.
