Author Topic: B6: Shift-V (list-clipboards) works correctly in the Find dialog  (Read 2364 times)
  • Hero Points: 210
« on: September 30, 2014, 09:57:24 PM »
This one has bugged me for a long time.
In V18 an earlier, using Shift-V to paste in the Find edit box would always replace all the text.
In V19, it doesn't do this anymore - it works correctly!
(I just noticed this, since I've trained myself not to even try).
*THANKS*
  • Moderator
  • Hero Points: 528
Re: B6: Shift-V (list-clipboards) works correctly in the Find dialog
« Reply #1 on: October 01, 2014, 02:58:05 AM »
I use Ctrl+Shift+V a lot but mostly in the edit window. Once I hit this problem in some dialog I was using, I fixed it. I probably didn't see this for a while because I'm typically pasting filenames which I want to take up the whole text box. That's probably why it took a while for me realize it wasn't inserting at the cursor.
