Author Topic: enumerate command padding broken since SE 11?  (Read 4623 times)
jbhurst
  • Hero Points: 33
« on: February 05, 2007, 11:19:11 pm »
Hi,
I can't believe I haven't hit this earlier -- I used to use the enumerate command all the time.
It seems to me that with SE 10 the command
enumerate 1 1 2
does what I want it to -- fill the block with numbers, starting at 1, incrementing by 1, and padding to 2 digits wide.
With SE 11.0.2 (and 12 beta), I don't get padding.
What gives?
John Hurst
  • Hero Points: 288
Re: enumerate command padding broken since SE 11?
« Reply #1 on: February 06, 2007, 09:17:04 am »
Confirmed - it's broken (at least in v11.0.2):
gdigitwidth is erroneously declared in local scope too:
You could fix it by replacing:
enum.e - enumerate() [line 189]:
   typeless start, increment, gdigitwidth;
   parse cmdline with start increment gdigitwidth;
   if (gdigitwidth=="") gdigitwidth=0;
with:
   typeless start, increment, digitwidth;
   parse cmdline with start increment digitwidth;
   gdigitwidth = (digitwidth=="") ? 0 : digitwidth;
  • Hero Points: 288
« Reply #2 on: February 06, 2007, 09:54:15 am »
v12 is also affected - added to SE2007 beta board.
mgweeks
« Reply #3 on: February 06, 2007, 04:51:01 pm »
Wow! Thats a cool command. Wish I'd known about it ages ago. Guess I need to read the manual.
« Reply #4 on: February 06, 2007, 05:19:46 pm »
Thanks for reporting this and for already posting a work-around, it will be fixed in future releases (though this fix did not make it in time for the next impending beta drop).
