Author Topic: Slickedit devs: What tool do you use for "make" ?  (Read 2695 times)
  • Hero Points: 210
« on: October 02, 2014, 05:43:11 pm »
This is always a vexing thing for developers, so I'm curious since you build Slick for so many different platforms.
What do you use for make for building slick?
  • Hero Points: 153
Re: Slickedit devs: What tool do you use for "make" ?
« Reply #1 on: October 02, 2014, 06:40:30 pm »
We use vsbuild (built in to our project system).
  • Hero Points: 509
« Reply #2 on: October 02, 2014, 08:32:59 pm »
The C/C++ > Cross Platform C++ Wizard project template is modeled after our project configurations, the primary difference being how we set up the build directories and a plethora of workspace environment variables to make sure that compile and link commands are done consistently.
The C/C++ Cross Platform C++ Wizard set ups builds for Windows (CL), Unix (g++), and MacOS (clang++) in both Debug and Release variants (for a total of six configurations).  The Unix configurations will also work with Cygwin or Mingw on Windows, of course.
  • Hero Points: 210
« Reply #3 on: October 02, 2014, 09:02:25 pm »
For debugging then?
Slick with gdb/wingdb, or visual studio?
  • Moderator
  • Hero Points: 507
« Reply #4 on: October 02, 2014, 09:17:31 pm »
On Windows we usually use Visual Studio to debug. We use our integrated GNU GDB debugging support on the other platforms.
In the future, we hope to get LLDB to working on Mac since GDB doesn't work as well as we would like on Mac.
  • Hero Points: 509
« Reply #5 on: October 03, 2014, 12:25:15 am »
The Cross platform C++ project template uses windbg on Windows and gdb integration everywhere else.
