Author Topic: B6: Backup History Browser: Typing in the FileSpecs filter can be *really* slow.  (Read 2210 times)
  • Hero Points: 189
It is sometimes being really slow.
Just now, it appeared to be locked up for at least 30 seconds.
When I broke (ctrl+alt+f2) I get this error:
Slick-C Error
ߓ
file=bhrepobrowser.ex offset=3201
OK
 Break key pressed.  Macro halted bhrepobrowser.ex 3201 bhrepobrowser:filterTree(F)   p_window_id: 641   p_object: OI_TREE_VIEW   p_name: ctltree1 bhrepobrowser.ex 3003 bhrepobrowser:filespecTimerCallback(861 F)   p_window_id: 5   p_object: OI_FORM   p_name:
  • Hero Points: 139
It looks like it was still filtering.
  • Hero Points: 189
I closed slick, opened it again.
Now, in Backup History when I type in "filespecs", it responds nearly instantaneously.
When I broke it before, it had been hung for more than 30 seconds.
HM.... I don't know what exactly the repro is, but if I play with the browser window a bunch, then typing in filespecs becomes incredibly slow.
No matter what I type in Filespecs, *everything* is filtered out (except the day headers).
  • Hero Points: 139
What if you type a '*'?
  • Hero Points: 189
I captured a profile of a time where the browser took a very long time to respond. Attached.
Also, when I saved the profile, I got a stack.
 Invalid argument
bhrepobrowser.ex 7101 _cbsave_BackupHistoryBrowser()   p_window_id: 131   p_object: OI_TREE_VIEW   p_name: ctltree1
files.ex 10469 call_list(_cbsave_)   p_window_id: 162   p_object: OI_EDITOR   p_name:
saveload.ex 85 save_file(C:\Users\joe\Documents\Slickedit\19.0.0\logs\profile.tsv,-O +DD -Z -ZR -E -S -E)   p_window_id: 162   p_object: OI_EDITOR   p_name:
files.ex 6552 save(-E,8)   p_window_id: 119   p_object: OI_EDITOR   p_name:
slickc.ex 25220 profile(save)   p_window_id: 119   p_object: OI_EDITOR   p_name:
  • Hero Points: 189
Oops, that last post was from a B5 install on another machine.
Here is another profile file - this time from B6.
Slick locked up for about 55seconds after I typed "as" (as in, asdfg...).
  • Hero Points: 139
Does it always happen after you expand older items?
  • Hero Points: 189
Seems to be related.
While "Other" is open, it is surely slower, but not always glacial.
Expand Other
Scroll to the bottom.
[size=78%]Type "*.c"[/size]
Select the last item.
Slick takes maybe 1 second to process - each time you click a different item.
Clear the Filespec
Do it again....
Then, sometimes, it starts getting glacial - in the 30sec to 1 minute time to respond.
My VsDelta directory has just under 2500 files, 1530 directories, and 24,456 versions.
Type a filespec.
