Author Topic: B6: Backhistory Browser: Filtering fail  (Read 1313 times)
  • Hero Points: 189
« on: October 08, 2014, 09:23:46 pm »
WRT FileSpec: I wasn't expecting wildcards, I was expecting list-buffers behavior where you can type "java" and it matches any filename with "java" in it. Funny thing -- list-buffers also takes wildcards like "A*.c" for any filename starting with A and extension=c, but it won't take "*.c;*.h"
Anyways, an easy repro for the filter not working:Collapse a day item, or "Older".
Enter a pattern, like "*.c".
Expand the item.
The newly expanded item is not filtered.
  • Hero Points: 139
Re: B6: Backhistory Browser: Filtering fail
« Reply #1 on: October 09, 2014, 12:57:44 pm »
Fixed for next drop.  Thanks for the report.
