Author Topic: B6: Changes to "debug *.*" dialog  (Read 1393 times)
lambertia
  • Hero Points: 14
« on: October 16, 2014, 08:42:43 pm »
Hi!
This isn't a bug but I wonder if we could squeeze in this change for all debug dialogs. It would be a great improvement and I'm sure I'll get lots of hero points for the suggestion (that's a hint):
  • Move the "Session Name" field to be the first in the dialog.
  • For each session name, remember the values of every other field.
  • When the user selects a different session name populate the fields accordingly.
  • Remember this information in the workspace.
I think I suggested this in some manner a few years ago.
It is less than ideal to have to manually re-enter debug targets all the time. Especially when I tend to have the same two or three I switch between at any one time.
Thanks for listening!
  • Moderator
  • Hero Points: 449
Re: B6: Changes to "debug *.*" dialog
« Reply #1 on: October 16, 2014, 10:42:05 pm »
Good ideas here. Thanks
  • Hero Points: 289
« Reply #2 on: October 16, 2014, 10:48:00 pm »
Ok, ok - you should really get one  ;)
