Author Topic: B6: Can't save turning off Source Diff under DIFFzilla  (Read 2328 times)
jkwuc89
  • Hero Points: 6
« on: October 17, 2014, 02:56:14 pm »
In the OS X version of beta 6, I am trying to turn off Source Diff and have SlickEdit save that choice by doing the following:
  • Open DIFFzilla
  • Click on Options
  • Turn off the Source Diff checkbox
  • Turn on other DIFFzilla options
  • Click on OK
When I re-open DIFFzilla after doing the steps above, Source Diff is still turned on and the other options I turned on are reset back to being off.
  • Moderator
  • Hero Points: 449
Re: B6: Can't save turning off Source Diff under DIFFzilla
« Reply #1 on: October 17, 2014, 02:58:39 pm »
On the "Files" tab of the DIFFzilla dialog, click the "IF END()" button to turn off Source diff.
jkwuc89
  • Hero Points: 6
« Reply #2 on: October 17, 2014, 04:21:23 pm »
Unfortunately, the suggestion above did not work.
On the Files tab, I clicked on the IF() button (which BTW is very difficult to see / make out on my MacBook Pro 15 with a Retina display).
I then clicked on Options and saw that Source Diff was turned off.  I turned on three other options (expand tabs, ignore trailing spaces, do not compare newline chars) and then, clicked on OK.
When I restarted DIFFzilla, SourceDiff was turned back on by default and the three other options listed above were turned off.
  • Moderator
  • Hero Points: 449
« Reply #3 on: October 18, 2014, 03:14:39 am »
No luck reproducing this so far. A video might help. Sometimes it's something subtle.
jkwuc89
  • Hero Points: 6
« Reply #4 on: October 20, 2014, 11:50:32 am »
The link below will take you to a screen capture video that shows what I am seeing. Let me know if you need any more information.
https://www.dropbox.com/s/d15up65l9qwuzkb/DIFFzillaNotSavingOptions.mov?dl=0
  • Hero Points: 139
« Reply #5 on: October 20, 2014, 01:02:18 pm »
I see it in the video, so far I can't reproduce it.
jkwuc89
  • Hero Points: 6
« Reply #6 on: October 20, 2014, 01:10:58 pm »
I think I found a workaround for this. On the Options tab in DIFFzilla, I deleted all of my recent sessions and all of my saved sessions. Saving DIFFzilla option changes in beta 6 is now working.
