The "load" command doesn't detect that a #include file has changed and won't recompile a slick c file if the #including file hasn't changed. Maybe a warning could be given that no recompile was done. e.g. If I change the definition of HI in test1.sh then load the code below, there's no change in the text string that appears.
#include "test1.sh"
_command void gptest() name_info(',')
_message_box(HI);
So now I have force_load
_command void force_load() name_info(','VSARG2_REQUIRES_EDITORCTL|VSARG2_READ_ONLY)
_save_file('+o');
load();
