Author Topic: accelerator characters not being highlighted in popup menus  (Read 1887 times)
  • Hero Points: 318
« on: October 19, 2014, 12:45:29 am »
Right click in an edit window to see context menu - there's no underlining of the accelerator character - or in any popup menu.
  • Hero Points: 318
Re: accelerator characters not being highlighted in popup menus
« Reply #1 on: November 02, 2014, 02:26:08 am »
In case you missed it, this is not fixed in RC2.
  • Moderator
  • Hero Points: 417
« Reply #2 on: November 02, 2014, 06:19:33 pm »
I believe you need to reconfigure Windows if you want menu accelerators. It may even depend on which version of Windows you're using and whether you've activated the menu with the mouse or the keyboard.
Accelerators on menus seems to be a bit more of a thing of the past. More OSes are trying to get rid of them. I'm not happy about it either.
  • Hero Points: 318
« Reply #3 on: November 03, 2014, 07:14:22 am »
Got them working now on Windows 7.  Thanks.
