Author Topic: Find/Replace in files dialog box too narrow  (Read 1986 times)
bengle
  • Hero Points: 4
« on: October 22, 2014, 10:20:41 am »
The "Find in Files" and "Replace in Files" dialog box is much too narrow.  For one thing, the tabs at the top are not all visible, requiring scrolling.
More importantly, the "Look in" drop down combo box is so narrow that you can't see what you are selecting.  I have some fairly long path names in the dropdown list, like "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\atlmfc" or "C:\Program Files (x86)\Windows Kits\8.1\Include\km".
Could this dialog box possibly be made wider?
Tim Kemp
  • Hero Points: 91
Re: Find/Replace in files dialog box too narrow
« Reply #1 on: October 22, 2014, 11:57:17 am »
Did you try resizing the box?
bengle
  • Hero Points: 4
« Reply #2 on: October 22, 2014, 01:29:20 pm »
Thanks.  I didn't even realize you could resize it.   :)
