Author Topic: B6: Linux: Function color code can be missed  (Read 2108 times)
PiezonTM
  • Hero Points: 8
« on: October 22, 2014, 04:22:11 pm »
I have the unfortunate situation of modifying code with a function definition format that I don't care for.  It did however exercise a possible problem when function names are color coded.  With the following example, the functName is not bolded to match the color coding.
int
functName
    int param1,
    int param2
When typing in the code the bolding on the functName disappears when the first paren is put on the next line.  For example, the following works:
int
functName (
    int param1,
    int param2
Is this expected?  I suspect not.
  • Moderator
  • Hero Points: 501
Re: B6: Linux: Function color code can be missed
« Reply #1 on: October 22, 2014, 04:25:57 pm »
It's a limitation
  • Hero Points: 494
« Reply #2 on: October 22, 2014, 07:37:52 pm »
If you have a fast enough machine, you can get that color coding to work using Symbol coloring.  If you just want to solve the problem for functions, you could make a custom symbol coloring scheme with rules just for coloring function names.
