Author Topic: Down arrow in 'Find Symbols' window inconsistent with 'Open' window  (Read 2225 times)
machish
I find it inconsistent how in 'Find Symbol', <down> will go through the history of what I typed previously. It also wipes out what I've just typed.
While in 'Open', <down> will move the selection in the list. This inconsistency is confusing. (Personally, I wish they'd both behave like 'Open', and reserve Alt+down for bringing up the history.)
I'm using Beta5 (because the Beta6 regression of tool windows was too annoying) on Win64.
-martin
  • Hero Points: 517
Re: Down arrow in 'Find Symbols' window inconsistent with 'Open' window
« Reply #1 on: October 24, 2014, 11:57:36 PM »
That is a good idea.  I think I can work that fix in.
