Author Topic: Win7x64 Beta6: Issue with insert-blankline-above  (Read 1257 times)
TKasparek
  • Hero Points: 27
« on: October 24, 2014, 07:44:19 pm »
I have insert-blankline-above assigned to ctrl-shift-enter as is the default for CUA I believe. In the following example:
for( int i; i < 10; i++ ) {
   // Have cursor on this line and execute insert-blankline-above
Having the cursor on the line after the for loop will cause insert-blankline-above to change the cursor location to after the conditional of the for loop; ie after the "10;".
Is this the expected behavior? This has been in SE for a long time, I figured I would mention it anyway.
  • Hero Points: 440
Re: Win7x64 Beta6: Issue with insert-blankline-above
« Reply #1 on: October 27, 2014, 06:31:39 pm »
Very tricky case, we are hitting some code that is trying to advance the cursor to the next part of a for loop on Ctrl+Enter.
