Author Topic: RC1, Win64, C language: Comment * now indented  (Read 4614 times)
jorick
  • Hero Points: 17
« on: October 30, 2014, 02:18:07 pm »
When editing a comment block, in v18 and B6 the * is on the first line so when you hit enter, a new line is formed with an * in the first column.
In RC1, the * is indented one space even if the previous line has the * in the first column.  The indentation also occurs on the previous line as well.
This also occurs during word wrap.
  • Hero Points: 151
Re: RC1, Win64, C language: Comment * now indented
« Reply #1 on: October 30, 2014, 02:30:36 pm »
Do you have an example comment you post that does this?  It's I can get it to keep the * in the first column, but maybe there's something else my comments are missing that triggers this.
jorick
  • Hero Points: 17
« Reply #2 on: October 30, 2014, 05:18:58 pm »
Here's an example where I added a paragraph:
* \anchor      BioBus_Initialize
* \brief       Initialize the BioBus module
* \details     The BioBus module is set up to run at 7.5 MBaud on an RS485
*              UART.  The UART is set up for Normal Multidrop Mode with
*              automatic address matching.
 *             Normal Multidrop Mode is a 9-bit protocol where the first byte
 *             has the 9th bit set to signal an address.  If the address
 *             matches the receiver's address, the packet is received.  If a
 *             mismatch occurs, the receiver isn't even turned on.
* \param[in]   zptInit           Initialization structure pointer
* \retval      Error_t           Result code (SUCCESS or FAILURE)
  • Hero Points: 151
« Reply #3 on: October 30, 2014, 05:40:45 pm »
I can easily reproduce it with that.  Thanks.
  • Hero Points: 151
« Reply #4 on: November 04, 2014, 08:12:34 pm »
Fixed.  This will be in either the next drop, or the first hotfix.
jorick
  • Hero Points: 17
RC3, Win64, C language: Comment * now indented
« Reply #5 on: November 05, 2014, 04:52:30 pm »
Still seen in RC3 (assuming RC3 is v19.0.0.12).
  • Hero Points: 151
« Reply #6 on: November 05, 2014, 05:11:02 pm »
Next after RC3.  RC3 came out on Nov 3.
