Author Topic: FIX:Docking group of tool-windows on left/top takes up entire application window  (Read 2882 times)
Rodney
  • Hero Points: 47
I don't remember who posted this, but it is fixed for the next drop. The mysterious "flashing" window is fixed too.
++rodney
Tim Kemp
  • Hero Points: 91
I've been noticing a "pinning" problem all over. It appears when a new window opens. The state of the docking group should be unpinned, but it shows up pinned. I've seen it when I open SlickEdit, when I open the debugger and when I drag a file tab out to create a new window. The only case where it's consistent is when dragging the file tab.
Is this the same thing?
Rodney
  • Hero Points: 47
No, and I'm not even sure what you're describing.
++rodney
Tim Kemp
  • Hero Points: 91
I start with something like this:
I click and drag o.txt outside the window to create a new window and end up with this:
It's not the end of the world. I can easily unpin the docked tools and go on my way, but it happens every time I do this. It also happens sometimes when I first open SlickEdit, when I go to debug, or exit from debug. Occasionally the bottom docked tools will also decide to pin themselves.
Rodney
  • Hero Points: 47
That sounds like your default floating layout being applied. Right-click on a floating document tab, go to Layouts and create one that has the windows unpinned. Make sure you set it as Default.
++rodney
Tim Kemp
  • Hero Points: 91
That looks like it was the problem. Is there any way to include the window size in the layout? My main SlickEdit window is full screen and when I drag a tab the new window is nearly the same size. Unfortunately all my screens aren't that big which means I immediately have to resize.
Rodney
  • Hero Points: 47
I'll put it on my list.
jimlangrunner
  • Hero Points: 31
I don't know if this is related or not, but it came about because of me trying the floating windows & fix in this thread.
I created "MyStandard" layout for my floating window.  given that I just love Find & Replace and Regex Evaluator, I always have them docked & minimized on the right margin of my main window.  I wanted them on the floater, so I added them. But I could only get F&R by floating it from the main window & docking on the right side of the floater.  So I did, and had F&R and RegEx rolled up on the right with the "standard" collapsed windows on the left.  When I saved & tested, I got the attached layouts.  (And I can't figure out how to insert the images inline.  Here's hoping)
Rodney
  • Hero Points: 47
Find and Replace does not support duplicates, so you can only have 1 instance.
++rodney
Tim Kemp
  • Hero Points: 91
Jim,
For inline images, I've been using http://imgur.com/. It's pretty straightforward and doesn't require any sort of login.
