Author Topic: RC2 - ([{' surround doesn't work with column selection  (Read 1748 times)
tim_k
  • Hero Points: 11
  • -Tim
« on: November 03, 2014, 10:05:15 pm »
Not sure if this is a bug or an unimplemented extension of the new selection surround feature...
Repro: select a column of text, and type one of the surround characters (,[,{ etc. The text is deleted and replaced with the typed character on each line of the column selection. Select text on a single line and it works fine.
-Tim
  • Moderator
  • Hero Points: 454
Re: RC2 - ([{' surround doesn't work with column selection
« Reply #1 on: November 04, 2014, 12:03:44 pm »
Use Shift+RButtonDown and drag to create multiple selections instead of creating a column selection.
tim_k
  • Hero Points: 11
  • -Tim
« Reply #2 on: November 05, 2014, 03:30:55 pm »
OK, that worked. I like the new feature, but would really like to see it in column selections too. Multiple cursors/selections is a neat feature I'm finding more uses for, but don't really use that much. I use column selection really really often and would love the surround characters to 'just work' in that mode as well.
-Tim
