Author Topic: RC4: No vsdiff window on Windows 7  (Read 2979 times)
jnairb
  • Hero Points: 11
« on: November 06, 2014, 02:59:26 pm »
Just installed RC4. When I try to run a diff, after entering file 1 & 2 names and hitting enter, no vsdiff window appears. If I try to close the file I was editing (file 1 of the diff), I get a message saying I can't close a file that's being diffed.
SlickEdit 2014 (v19.0.0.13 64-bit)
Serial number: FE11502_BETA
License type: Beta License
License expiration: 2014-11-20 05:01:00
Build Date: November 05, 2014
Emulation: Brief
OS: Windows 7 x64
Memory: 61% Load, 5006MB/8150MB Physical, 5161MB/16298MB Page File, 240MB/8388607MB Virtual
Screen Size: 1920 x 1200
Project Type: No project open
Language: .e (Slick-C)
Encoding: Automatic
Installation Directory: c:\Program Files\SlickEdit\beta\ (non-removable drive,NTFS,133248MB free)
Configuration Directory: C:\Users\bej\SlickEdit\19.0.0\ (non-removable drive,NTFS,133248MB free)
  • Hero Points: 137
Re: RC4: No vsdiff window on Windows 7
« Reply #1 on: November 06, 2014, 03:38:01 pm »
I'm looking into this.
Were you running it from the editor?
jnairb
  • Hero Points: 11
« Reply #2 on: November 06, 2014, 03:40:27 pm »
Yes, I ran the diff command from the editor, entered files to compare in the dialog, and then after OK to run... nothing.
  • Hero Points: 137
« Reply #3 on: November 06, 2014, 04:17:48 pm »
Can you send me your vrestore.slk from your config directory?
dwgriffith
« Reply #4 on: November 06, 2014, 08:21:09 pm »
I have the same issue.
I tried opening the two files to perform the difference from buffers and it does not present the expected difference view. I then tried the vsdiff application and it does not bring the differencing widow either. they both open the dialog box to launch the selected files. When the difference is launched, I see a quick popup of the differencing guase then it disappears and nothing else shows up. You can close any files associated with the difference due to an error being reported that differencing is in process. the only way to stop the differencing is to close the slickedit instance.
  • Hero Points: 137
« Reply #5 on: November 06, 2014, 08:35:19 pm »
There will be an RC5 coming that will address this.  In the meantime, if you PM me an email address I'll send you a fix for this.
