Author Topic: RC5. Mac, Slick Crashed (SIGSEGV)  (Read 1042 times)
  • Hero Points: 170
« on: November 07, 2014, 08:23:04 pm »
Attached is the crash report.
I was trying to "Reload with Encoding...".
I tried several times on A.mm file, and Slick appeared to do nothing - totally ignoring the change.
I switched to B.h file, and the encoding change worked as expected.
I switched to C.mm file, and again, the encoding change worked.
Then, I went back to A.mm, and tried again several times.
Finally, Slick made the change to Utf16 (and so, ended up displaying garbage because the file is 8bit).
Then, I could not get slick to change A.mm nor C.mm back to text or UTF8.
[size=78%]Finally, Slickedit had enough of that, and crashed.[/size]
[/size]
[/size]
[/size][size=78%]So, I dunno if Slick has a problem with *.mm, or just A.mm.[/size]
[/size][size=78%]Either way, something is seriously busted here.[/size]
[/size]
