Author Topic: Cannot check out file from Mercurial repository  (Read 1817 times)
HTrammel
« on: November 10, 2014, 10:35:48 pm »
I moved to Mercurial as my source code repository and I have configured SlickEdit according to instructions. The 'Mercurial executable path' is correct and the 'Push/Pull is interactive' is on. When I attempt to open a file from the repository and select "Check out" as the action, SlickEdit crashes. It is totally reproducible.
  • Hero Points: 134
Re: Cannot check out file from Mercurial repository
« Reply #1 on: November 11, 2014, 01:28:44 pm »
How are you doing this?  Can you include steps?  I don't have a check out item on the menu.
HTrammel
« Reply #2 on: November 11, 2014, 02:16:13 pm »
File > Open > Outside Click (context menu) > Check Out
I have added a Jing Video Capture.  It is a shockwave file.  Hope it helps.
  • Hero Points: 134
« Reply #3 on: November 11, 2014, 06:31:16 pm »
Thanks, I was able to reproduce the problem.  This will be fixed in a future hot fix.
