Author Topic: RC5 Mac: "vsdiff dir1/ dir2/" always closes  (Read 2386 times)
  • Hero Points: 170
« on: November 11, 2014, 01:54:43 am »
from a terminal, run "vsdiff" to compare two directories of files.
Slick shows a nice tree view.
Double click one of the files to view the side-by-side differences.
No matter how you close the side-by-side diff window, the tree-view window also closes.
This means you only get to see one of the different files, then you have to start over.
  • Hero Points: 379
Re: RC5 Mac: "vsdiff dir1/ dir2/" always closes
« Reply #1 on: November 11, 2014, 03:05:05 pm »
This appears to be a Mac only bug and it's not new. After a little bit of research I'm surprised this doesn't happen on all platforms. I think the tree view needs to be modal so there's a message loop.
  • Hero Points: 170
« Reply #2 on: December 11, 2014, 08:47:41 pm »
This is still a problem in 19.0.1.
  • Hero Points: 128
« Reply #3 on: December 12, 2014, 04:12:06 pm »
I'm sorry, this one sort of fell through the cracks.  The fix is in two macro files.  If you PM me an email address I'll send them to you.
  • Hero Points: 170
« Reply #4 on: December 15, 2014, 08:20:45 pm »
Cool, those updated *.e files make it work now!
  • Hero Points: 170
« Reply #5 on: December 15, 2014, 09:03:03 pm »
RUn vsdiff on two directories with several different files.
Double-click one of the different files to get the diffs.
"Next-diff" until you get the "no more differences, close now?"
Answer NO.
Press ESC.
Both the diff and the multi-diff windows close.
Only the diff window should close.
Until the "no more diffs" dialog, only the diff window does close.
  • Hero Points: 128
« Reply #6 on: December 31, 2014, 04:47:25 pm »
I can't reproduce this one.  Are you clicking Next-Diff with the mouse?  Are you clicking "No" to the "close now?" dialog with the mouse?
