Author Topic: B6, Win64: Error message on ; in struct  (Read 3160 times)
jorick
  • Hero Points: 17
« on: November 12, 2014, 06:47:48 pm »
When I type a ; when finishing a typedef'd struct element, I get a couple of dialog boxes popping up.  The first one reads:
Failed to save configuration to 'C:\Users\[redacted]\Documents\My Slick Edit Config\19.0.0\vslick.sta'.
Error reading file
The second message reads:
Unable to save the configuration
Do you want correct the problem and try again?
If you can't correct the problem, your configuration changes will be lost.
(Note the missing "to" in the second line.)
The vslick.sta file is missing for some reason, but vslick.sta.bak is there.
« Last Edit: November 12, 2014, 06:49:20 pm by jorick »
jorick
  • Hero Points: 17
Re: B6, Win64: Error message on ; in struct
« Reply #1 on: November 12, 2014, 06:54:03 pm »
I renamed vslick.sta.bak to vslick.sta but still get the same message.
  • Hero Points: 504
« Reply #2 on: November 12, 2014, 10:24:16 pm »
Do you have "Beautify while typing" turned on?
It sounds like something in your configuration is toast.
« Last Edit: November 12, 2014, 10:49:48 pm by Clark »
