Author Topic: Storing toolwindow layouts per workspace should be optional.  (Read 2658 times)
  • Hero Points: 337
« on: November 13, 2014, 11:20:14 am »
I opened a new workspace and found all my floating toolwindows disappeared.  I don't particularly want to have to re-open, re-size and re-position all my floating toolwindows every time I create a new workspace or open one that I haven't opened with slick V19 before.  In my opinion this should be optional or slick should allow you to save and restore toolwindow layouts.
  • Hero Points: 337
Re: Storing toolwindow layouts per workspace should be optional.
« Reply #1 on: November 15, 2014, 09:36:00 am »
Can't reproduce this problem now.  Opening "legacy" workspaces or creating a new one leaves the toolwindows as they are which is exactly what I want.  What I would also like is the ability to hide all my floating toolwindows with a single command, and another command to bring them all back.  "Hide when application is inactive" doesn't solve this because I sometimes want all my toolwindows hidden when slick has the focus.
...Later - looks like the commands save_named_state and load_named_state can be adapted to do this, just need to make load_named_state not restore buffers.  The code below seems to (mostly) work - but has to be added to restore.e because there's no access to the restore2 function.  If you have any floating edit windows there are some problems - they reappear with no buffer open, you can open one but the slick command line window won't open at the bottom and if you have a floating edit window already open it gets hidden behind the toolwindows.  save_named_state and load_named_state don't have these problems.
static _str _load_named_layout_callback(int reason, var result, _str key)
   _nocheck _control _sellist;
   _nocheck _control _sellistok;
   if (key == 4) {
      item := _sellist._lbget_text();
      filename := _ConfigPath():+'windowstate_nobuffers.slk';
      status := _ini_delete_section(filename,item);
      if ( !status ) {
         _sellist._lbdelete_item();
   return "";
_command void load_named_layout(_str sectionName="") name_info(',')
   if ( sectionName=="" ) {
      _ini_get_sections_list(filename,auto sectionList);
      result := show('-modal _sellist_form',
                     "Load Named State",
                     SL_SELECTCLINE,
                     sectionList,
                     "Load,&Delete",     // Buttons
                     "Load Named State", // Help Item
                     "",                 // Font
      if ( result=="" ) {
         return;
      sectionName = result;
   status := _ini_get_section(filename,sectionName,auto tempWID);
   if ( status ) return ;
   origWID := p_window_id;
   p_window_id = tempWID;
   //_close_all2();
   //p_window_id = tempWID;
   restore2('', '', false, true, true);
   if ( _iswindow_valid(origWID) ) {
      p_window_id = origWID;
   _delete_temp_view(tempWID);
_command void save_named_layout(_str sectionName="") name_info(',')
      result := "";
      if ( sectionList==null ) {
         // If there are no section names stored already,
         // just prompt for a name.
         result = textBoxDialog("Save Named State",
                                0,
                                0,
                                "Save Named State",
                                "Save Named State");
         if ( result==COMMAND_CANCELLED_RC ) {
            return;
         result = _param1;
      } else {
         // If there are names, show the list with a combobox
         // so they can pick or type a new name.
         result = show('-modal _sellist_form',
                       "Save Named State",
                       SL_SELECTCLINE|SL_COMBO,
                       sectionList,
                       "Save,&Delete",     // Buttons
                       "Save Named State", // Help Item
                       "",                 // Font
      if ( result=="" ) return;
   int orig_view_id=_create_temp_view(auto state_view_id);
   p_window_id=orig_view_id;
   save_window_config(true,state_view_id);
   int status=_ini_put_section(filename,sectionName,state_view_id);
