Author Topic: Python block comments broken in v19  (Read 3553 times)
mlevedahl
« on: November 17, 2014, 01:52:45 PM »
In python, a sequence of 3 single quotes or double quotes are used to denote a block comment. v19 does not recognize the closing set of single quotes unless on the same line. e.g.
""" some stuff
     works"""
''' a single line using triple quotes works '''
''' but a comment on multiple lines
   ends up treating the rest of the file as a comment'''
  • Hero Points: 151
Re: Python block comments broken in v19
« Reply #1 on: November 17, 2014, 02:32:36 PM »
Reproduced it, taking a look.
  • Hero Points: 151
« Reply #2 on: November 17, 2014, 09:12:49 PM »
Fixed.  Unfortunately, it's not hot-fixable, so it will be in the first update.
IkerAriz
  • Hero Points: 6
« Reply #3 on: November 19, 2014, 06:26:10 PM »
This seems to apply to triple-quoted strings more generally. Eg, setting a variable to TQ string that spans multiple lines.
Will the update be available soon? The loss of syntax coloring really puts a damper on using SE for python projects.
Regards,
Iker
brainsalad
« Reply #4 on: November 21, 2014, 04:49:52 PM »
Update soon, please.  I have temporarily switched to using triple double-quoted doc strings, and it pains me.  If I can't switch back to triple single quotes soon, I might die.  I am aware that is unreasonable.
  • Hero Points: 535
« Reply #5 on: November 23, 2014, 03:38:28 AM »
Sorry about this issue. We know we can't wait that long for an update which fixes this.
