Author Topic: SE Module Load Process : Menu Collision : New Menu definition should override ol  (Read 6204 times)
PurdueEEGrad
  • Hero Points: -17
I am testing out SE RC5 - and ran into a problem with SE custom menus - as
explained herein.
When developing Slickedit code modules - new definitions of macros simply
override the old - when a new SE module is loaded - that redefines
existing macros.
The constant 'reload' of SE modules - simple updates the existing macros -
during SE code development.
---------- Introduction : SE Menu loading - does NOT update existing menus ---
Just like Slickedit custom macros - custom Slickedit menus - should be
updated - as the Slickedit menu code is being developed.
Each load of the latest version of the SE module - should update existing
menu definitions.
As it turns out - this does not seem to happen with the attached modules.
I am not sure if this is a (1) SE Menu size limitation issue - or (2) a
more fundamental problem with updating an existing 'user menu definition'.
---------- Attachments ---------------------------------------------------
[1] MDI Menu Item stub module -
[2] [Small Test] MDI Menu Item Definition module -  ...V1
[3] [Large Test] MDI Menu Item Definition module -  ...V2
[4] Screenshot [1] - shows delete of menu - for reload of updated SE module.
The intent is that [2 or 3] is loaded and overrides [1].
Technically speaking - the general use case is to load many LLP (Low Level
Pattern) grep environments - for different code domains.
The required Slickedit feature - would be the ability to just redefine (1)
a MDI menu item - or (2) an existing menu definition.
Note that [3] will NOT load - due to menu size limitations of SE.
Ideally, [2] should override [1] - and [3] should override [2].
------------ Test replication -----------------------------
The following shows that -
(A) Load [1]
(B) Load [2] - Should redefine [1] to the new menu architecture.
(C) Load [3] - Should redefine [2] to the new menu architecture.
.. does not work.
------------ Discussion : Additional bugs (?) -------------
Normally - (B) should work - since attachment [2] works - when loaded.
One workaround - is the remove the menu definition - prior to
a reload of the new (menu) architecture.
Removing the menu definition - post (A,B or C) - would be;
SE MDI Menu -> Macro -> Menus : (Delete) => _ccv_SEM_01_Base_srh_mnu
The problem is that the Menu (Delete) operation - does not seem to work.
I have attached a screen shot to show part of the delete operation.
In a nutshell - you can't delete a menu item and reload it. Once loaded,
even if the menu is 'deleted' - you will never be able to reload it or
use it again. The fallback position is a previous ZIP of the config
directory - which provides a clean SE state space - to load in the
menu.
Note : I am using a *.Zip file of the My Slickedit Config directory - as a
fallback reference point - when testing out the SE module load process.
In this way the same fallback reference point - is consistent in testing.
If you 'fallback' to a previous Zip file - with no menu target defined -
you can always 'reload' the menu definition - unless its too big - and
it hits the SE menu size limit.
------------ Summary --------------------------------------
There are all sort of issues with custom SE menu artifacts - that simply
do NOT occur with SE custom macros (defined via SE code modules).
In a nutshell - you can not delete or redefine menu items easily - and
thus you really have a hard time - pushing the envelope - of the SE custom
menu features.
As always, I hope I am not missing something simple - and this is really a
bug - or something that is not 'by design'.
