Author Topic: moveline  (Read 2164 times)
byates
  • Hero Points: 8
moveline
« on: November 30, 2014, 03:31:10 pm »
I like the moveline functionality and map move_lines_up() and move_lines_down() to ALT-UP and ALT-DOWN.
However, I think the implementation of these functions need a little tweaking. There are two problems:
  • When a selection is made using SHIFT-Cursor movement, one extra line is often included. This will happen when the cursor is in the first column.
  • The whole screen scrolls instead of the line (or selection) just moving. I find this very jarring.
I have patched the moveline.e file to correct these behaviors. Feel free to include this in the next hotpatch or release.  ;)
