Author Topic: Totaling up a column of numbers  (Read 3860 times)
chris.aiken
« on: December 18, 2014, 12:49:22 pm »
I'd like to be able to highlight a column and total the numbers within it.
Any suggestions would be appreciated.
Re: Totaling up a column of numbers
« Reply #1 on: December 18, 2014, 02:05:06 pm »
Using the SlickEdit command-line (brought up using ESC in most emulations) use the "add" command.   It will sum up the numbers in the selection.  It can even handle operators, selecting 100 * 100 will print the multiplied result.
