Author Topic: How to determine that an integer entry in a hash table is missing?  (Read 2254 times)
Bamsen
  • Hero Points: 8
This code is working for strings:
  _str Linjer:[];
  _str sTemp;
  if (Linjer:["OK"]._isempty()) { Linjer:["OK"]="1"; } else { Linjer:["OK"]=Linjer:["OK"] "1"; }
  if (Linjer:["OK"]._isempty()) { Linjer:["OK"]="2"; } else { Linjer:["OK"]=Linjer:["OK"] "2"; }
  for (sTemp._makeempty();;)
    Linjer._nextel(sTemp);
    if (sTemp._isempty()) break;
    insert_line(sTemp " = " Linjer:[sTemp]);
What I really want is for the hash to be of type integer so I can add each value.
But for the first one I can not check if the hash exist.
So if I have
  int Linjer:[];
How can I check if Linjer:["OK"] exists?
Morten
Bamsen
  • Hero Points: 8
Re: How to determine that an integer entry in a hash table is missing?
« Reply #1 on: January 29, 2015, 08:00:18 am »
After trying for days, of cause I find it right after posting.  ::)
if (Linjer:["OK"] == null) { Linjer:["OK"]=2; } else { Linjer:["OK"]+=2; }
« Reply #2 on: January 29, 2015, 01:30:11 pm »
Also take a look at the builtin _indexin() method:
typeless a:[];
a:['key1']=5;         // a._indexin('key1') will be true
