Author Topic: undocked Message List doesn't want to resize  (Read 3068 times)
evanratt
  • Hero Points: 23
« on: February 04, 2015, 03:50:22 PM »
I'm experiencing some oddness with the Message List tool window. I undocked it, and am trying to drag the edge to make it larger. It seems that when I drag the edge too far horizontally (making it wider), the window snaps back to its smaller original size. This happens both when I drag the corner of the window or the right side edge. I've tried unchecking the "Dockable" option in the context menu, but it still happens.
SlickEdit 2014 (v19.0.1.1 64-bit)
Serial number: WB824242
Build Date: December 10, 2014
Emulation: Epsilon
OS: Windows 7 x64
Memory: 23% Load, 3815MB/16309MB Physical, 4881MB/32617MB Page File, 651MB/8388607MB Virtual
Shell Info: C:\TCCLE13x64\tcc.exe
Screen Size: 1920 x 1200, 1200 x 1600
Project Type: Cpp
Language: .process (Process)
Encoding: Text, SBCS/DBCS mode
Installation Directory: C:\Program Files\SlickEditV19.0.1 x64\ (non-removable drive,NTFS,56266MB free)
Configuration Directory: C:\Users\evan\Documents\My SlickEdit Config\19.0.1\ (non-removable drive,NTFS,56266MB free)
Spill File: c:\temp\$slk.7432 (non-removable drive,NTFS,56266MB free)
Rodney
  • Hero Points: 54
Re: undocked Message List doesn't want to resize
« Reply #1 on: February 04, 2015, 04:05:21 PM »
Reproduced. I believe it is trying to maintain whatever original size it starts with. Thanks for the report.
++rodney
evanratt
  • Hero Points: 23
« Reply #2 on: February 04, 2015, 04:24:33 PM »
If it helps, I've found that if I make the "Description" column wider, I can make the window wider. If nothing else, it's a temporary workaround.
Rodney
  • Hero Points: 54
« Reply #3 on: February 04, 2015, 04:28:57 PM »
Yep. If you make any of the columns wider such that you get a horizontal scrollbar, you can size the window up to the extent of the scrollbar.
Rodney
  • Hero Points: 54
« Reply #4 on: February 10, 2015, 11:33:30 PM »
This is not hotfixable, but it is fixed in the next point release (TBA). Thanks for the report!
++rodney
