Author Topic: Eclipse hangs and not responding - When edit some .mac file in IBM HLASM mode  (Read 10783 times)
Praveen Kumar
Opening the attached (SRVIIA.mac/FW11NZ.mac) file hangs and brings eclipse to not-responding mode when we try to edit the file in IBM HLASM mode of slickedit.
Similar issue happened in *.asm file and it was addressed by applying your hot fix. http://community.slickedit.com/index.php/topic,10733.0.html
Unfortunately that hot fix is not addressing the issue and guess that fix is only for .asm files.
Also attached .log & gif file FYR,
« Last Edit: February 10, 2015, 04:51:55 am by Praveen Kumar »
Praveen Kumar
Can anyone help...?
Praveen Kumar
Attached hot fix addressed this issue as well.
Thanks to Lee!!
