Author Topic: Eclipse stops working and crashes when open *.mac file in slickedit (IBM HLASM)  (Read 12760 times)
Praveen Kumar
Opening the attached .mac file stops eclipse required force close, when open *.mac file in IBM HLASM mode of slickedit.
Similar issue happened in *.asm file and it was addressed by applying your hot fix. http://community.slickedit.com/index.php/topic,10733.0.html
Unfortunately that hot fix is not addressing this issue.
Eclipse log file looks empty.
Also attached .gif file FYR,
This appears to be a new issue, I have reproduced at least one of the cases.  I am investigating the problem and will let you know when I have something.
Praveen Kumar
Thank you Lee.
I have a hotfix for Window 32-bit build, which should address the lockup, attached to this post.  This does include the previous fix which you submitted before.
You will need to bring up the SlickEdit command-line (bound to ESC in most emulations) and use the load-hotfix command.   You will be prompted for a zip file (see attachment), and then restart Eclipse.  Do let me know if this resolves your issue, or if you happen across any other problems just start a new forum post.
« Last Edit: February 27, 2015, 02:14:26 PM by Lee »
Praveen Kumar
Error loading hot-fix.
"Invalid hot fix. Could not open manifest: File not found"
Please find the attached image,
My apologies, I have corrected this problem with a new hotfix package.  Attached is the corrected download.
Praveen Kumar
Thanks Lee!
hot-fix loaded successfully but unfortunately it's not addressing the issue.
Eclipse still crashes even after loading the hot fix.
Did you try restarting Eclipse?  The fix worked for the examples you posted, but I may need another test case or more info about your configuration to see if additional fixes are required.
Praveen Kumar
Sorry for the delay!
Yeah, After restart it is working good.
Thanks for the quick fix Lee:-)
