Author Topic: Slickedit core for eclipse luna  (Read 8005 times)
bremenpl
  • Electrical Engineer
« on: February 18, 2015, 12:39:22 pm »
Hello there,
I have just installed a trial licence of eclipse core in eclipse luna, but I cant see any new features- Theres no Slickedit specific code completion and etc. Does it work correctly under Luna? I am abble to go to clickedit prefferences though.
Re: Slickedit core for eclipse luna
« Reply #1 on: February 18, 2015, 01:04:24 pm »
If the file was previously open before Core plugin was installed, you may need to re-open with the SlickEdit editor.  If it is not a SlickEdit editor, you can right-click in the file and there should be a menu item Switch to SlickEdit.  Also, you may need to check Eclipse Preferences > General > Editors > File Associations to ensure the extension is using SlickEdit Editor as the associated editor.
