Author Topic: search not working  (Read 5250 times)
brian40509
search not working
« on: April 09, 2015, 06:52:35 pm »
SlickEdit 2012 (v17.0.3.0 32-bit)
OS:Linux
Find suddenly stops working.  Find dialog set as follows:
Search for: nth_order_spaces
Look in: <Current Buffer>
Search options: Match whole word, List all occurrences, Bookmark all matches
Search Results window: <Auto increment>
Find was working then for some reason it stopped.  HELP!!!
  • Hero Points: 322
Re: search not working
« Reply #1 on: April 10, 2015, 01:50:07 am »
If restarting, rebooting etc didn't help then try this
1. export all your configuration options via tools -> options
2. close slick, backup your configuration folder
3. delete the vslick.stu file in your configuration folder
4. restart slick
If that doesn't work, try a brand new empty config folder vs.exe +new -sc some-empty-folder, then import your saved configuration options.
brian40509
« Reply #2 on: April 10, 2015, 01:50:15 pm »
FIXED
I had to try a brand new empty config folder vs.exe +new -sc some-empty-folder, then import your saved configuration options to get search working.  But it is working.
Thanks for your help.
Cormier
« Reply #3 on: January 03, 2018, 11:54:15 am »
FIXED
I had to try a brand new testomax review empty config folder vs.exe +new -sc some-empty-folder, then import your saved configuration options to get search working.  But it is working.
I tried that too Brian but it didn't work for me. Is there anything else I could try?
« Last Edit: September 11, 2019, 08:31:13 am by Cormier »
  • Hero Points: 322
« Reply #4 on: January 03, 2018, 09:14:01 pm »
Are you a real person?  If so, what is one hundred minus 23 times two?  (spammers post messages like yours sometimes.)
Try rebooting your PC.  What platform and version of slick are you using?  How do you initiate the search?
Does search work with an empty configuration folder before you import your configuration options?  If so, try selectively importing your config options until you find one that makes it go wrong.
