Author Topic: DIFFzilla sessions panel resizing...  (Read 1691 times)
joecar
  • Hero Points: 9
  • engineer/gearhead
« on: April 29, 2015, 07:21:46 pm »
Is there a way to resize the DIFFzilla sessions panel (for example by grabbing/moving the vertical space between the panels)...?
 ( see attached pic, you can see that I tried to make the sessions panel wider by making the DIFFzilla window wider, this is cumbersome and still did not give me enough width )
Manipulating the horizontal scroll bar becomes tedious (and slows down productivity), especially when with dozens of sessions (each with long pathname).
Thanks, appreciated.
« Last Edit: April 29, 2015, 07:26:24 pm by joecar »
  • Hero Points: 134
Re: DIFFzilla sessions panel resizing...
« Reply #1 on: April 29, 2015, 07:23:08 pm »
Not right now.  I'll file a feature request for this.
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #2 on: April 29, 2015, 07:24:13 pm »
Quick reply, thanks :)
Also, I would make this request for any window that has a fixed size panel (to be able to resize on the fly).
  • Hero Points: 134
« Reply #3 on: April 29, 2015, 07:26:10 pm »
The dialog itself is re-sizable right to left, that won't help too much though.
JimmieC
  • Hero Points: 16
« Reply #4 on: April 29, 2015, 07:41:37 pm »
Further, I would like the "Project Properties->Add Tree" & "Project Properties->Add Files" to remember the last width adjustment. I have to go to several directories to setup a project, some by tree and then some by files. The file extension list exceeds the default window size so I have to resize it every time I use it.
Additionally, I like to move that dialog over so that I can see the file list. SE does not remember the dialog location so I have to move it every time I use it.
It would be nice for all dialogs to recall the user's preferred window size and location. Of course, for laptops, it would have to take into account dual screen (or different screen size) when docked and native monitor when un-docked.
See attached images.
Jim
joecar
  • Hero Points: 9
  • engineer/gearhead
« Reply #5 on: April 30, 2015, 05:10:50 pm »
Yes, it does not help, the sessions panel is still too narrow.
