Author Topic: Odd Window Scroll  (Read 1684 times)
Tim Kemp
  • Hero Points: 91
Odd Window Scroll
« on: April 30, 2015, 07:53:14 pm »
I have the same file open in two windows. In the one that's closer to the top of the file I'm typing on a line. It doesn't change the line count. In the other window, the text is scrolling down as though I was pressing Enter instead of typing.
SlickEdit Pro 2014 (v19.0.2.5 32-bit)
\Build Date: April 10, 2015
Emulation: CUA
\OS: Windows 7 x64
Memory: 44% Load, 3601MB/8097MB Physical, 3800MB/16192MB Page File, 306MB/4095MB Virtual
Screen Size: 1920 x 1080, 1680 x 1050, 1920 x 1080
  • Hero Points: 470
Re: Odd Window Scroll
« Reply #1 on: April 30, 2015, 10:18:53 pm »
I've seen something like this when I was typing in a javadoc comment. The attempted comment wrapping was causing scrolling in the non-active window. We're you typing in a comment?
Tim Kemp
  • Hero Points: 91
« Reply #2 on: May 01, 2015, 07:00:27 pm »
It could have been in a comment. I can't seem to get it to happen again. When it was happening it was very consistent. I scrolled around quite a bit and it happened every time i typed something. Now, in the same file, it doesn't happen at all.
Phil Barila
  • Hero Points: 61
« Reply #3 on: May 02, 2015, 06:03:15 pm »
I've seen the same thing, whether typing in a comment or not.  It "felt" to me like the window that was lower was using a byte count, rather than a line count, to determine the start of the view, and when the file was modified above the view, it moved the byte count across a newline, and that's when the scroll happened.  Total conjecture on my part.
Tim Kemp
  • Hero Points: 91
« Reply #4 on: May 02, 2015, 10:35:59 pm »
That was the feeling I had too: each character I inserted pushed the lower window down by a line and then as I deleted them it went up a line at a time. I don't remember for sure if the line I was editing was comment or not, but I don't think it was.
