Author Topic: Same file in multiple buffers  (Read 1713 times)
link
  • Hero Points: 3
« on: June 29, 2015, 08:07:51 pm »
I have a set of files that are constantly being reloaded when I lose focus and go back to SlickEdit, sometimes causing data loss if I'm not careful (though I can usually recover the lost data from the backup history).  It appears that each file has two or more buffers associated with it.  I'm not doing anything unusual to open the file, I'm opening them from project-load or using select-buffer.  I found another post with this problem but it determined that it was caused by case insensitivity issues.  I'm on Linux, so that's not likely to be the culprit.  Any ideas?  I'm using 64-bit 19.0.2.5 on Fedora 21.
