Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
Symbol and Scheme Color Issues
« previous
next »
Reply
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Symbol and Scheme Color Issues (Read 3060 times)
TKasparek
Senior Community Member
Hero Points: 29
on:
June 30, 2015, 04:11:08 AM »
I've been trying to create another dark background based color set for myself. I can't get SE to correctly save my options. I do the following:
Rename config directory to start fresh
Load attached config options for Appearance (only contains symbol coloring)
Tools-Options-Appearance-Symbol Coloring
Rename
TEK Symbol Color
to
TEK Light Background Symbol Coloring
Click
Save As
and save a new copy as
TEK Dark Background Symbol Coloring
Hit
OK
and re-enter Symbol Coloring, it's back to the old value.
Try to edit compatibility: Click
Edit Compatibility
for
TEK Symbol Color
and add
TEK Color Scheme
Hit
Apply
, now click on Colors.
TEK Symbol Color
is not in the list of Associated symbol coloring scheme for
TEK Color Scheme
SlickEdit Pro 2014 (v19.0.2.5 64-bit)
Serial number: WMX110555
Build Date: April 10, 2015
Emulation: CUA
OS: Windows 7 x64
OS Version: 6.01.7601 Service Pack 1
Memory: 32% Load, 5269MB/16325MB Physical, 4797MB/32649MB Page File, 259MB/8388607MB Virtual
Screen Size: 2560 x 1440
Project Type: No project open
Language: No file open
Encoding: No file open
Installation Directory: C:\Program Files\SlickEdit Pro 19.0.2\ (non-removable drive,NTFS,120288MB free)
Configuration Directory: C:\Users\Tom\Documents\My SlickEdit Config\19.0.2\ (non-removable drive,NTFS,120288MB free)
Report to moderator
Logged
Sandra
SlickEdit Team Member
Hero Points: 36
Re: Symbol and Scheme Color Issues
Reply #1 on:
July 07, 2015, 02:36:49 PM »
I've reproduced these problems. Looking into them now.
Report to moderator
Logged
Sandra
Hero Points: 36
Reply #2 on:
July 13, 2015, 01:10:04 PM »
A fix for this will be in the next release of the hotfix. Thanks for the bug report. The steps to reproduce made it easy on me.
Report to moderator
Logged
Reply
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
