Author Topic: Need new code for determining Visual Studio 14 location [vchack.e]  (Read 2067 times)
jej45
seems we need an update for VS 2015
  • Hero Points: 444
Re: Need new code for determining Visual Studio 14 location [vchack.e]
« Reply #1 on: August 03, 2015, 06:19:23 pm »
Thanks for the heads up. We will look into this for v20.
jej45
« Reply #2 on: August 07, 2015, 04:23:16 pm »
Are there any plans to improve the C++ lexer to accommodate C++11/14? Especially, SlickEdit doesn't seem to accommodate the auto feature (the compiler deduces the variable's type).
  • Hero Points: 444
« Reply #3 on: August 07, 2015, 06:33:26 pm »
The following "auto" example works correctly:
struct MYSTRUCT {
    int m_x;
    int m_y;
void main(int argc, char *argv[]) {
    MYSTRUCT mys;
    auto abc=mys;
    abc.   <-- Try alt+dot here
Unfortunately, it isn't realistically possible to support all uses of auto. It's gets very complex. If there is a particular instance we don't handle, try posting it.
As for C++11 support, I'm not sure if more support will make it for v20. This is a high priority feature though.
  • Hero Points: 288
« Reply #4 on: August 07, 2015, 07:12:10 pm »
Thanks ! Highly appreciated :)
jej45
« Reply #5 on: August 12, 2015, 11:40:58 pm »
Try this
#include <vector>
using namespace std;
struct two
   int a;
   int b;
using two_stash = vector<two>; // Looks like SlickEdit doesn't understand using!
void func2()
   two_stash ary = { { 1, 2 }, { 3, 4 }, { 5, 6 } };
   auto itr = ary. // doesn't work
   int i = itr1-> // doesn't work
