Author Topic: Can I wrap the search automatically ?  (Read 1841 times)
rex99
« on: September 25, 2015, 03:51:03 pm »
Upon searching I eventually get the dialog "End of file reached. Continue searching at the beginning" message.
Can I change a configuration setting so this it automatically wraps to the beginning ?
Roe
Re: Can I wrap the search automatically ?
« Reply #1 on: October 23, 2015, 02:11:34 pm »
Go to menu Tools>Options, then Editing>Search and there is an entry where you can configure the "wrap at beginning/end".
