Author Topic: Minimize of windows very annoying...  (Read 3493 times)
TKasparek
  • Hero Points: 29
« on: September 29, 2015, 02:58:27 PM »
If you pull a editor tab out of the main window and minimize, it won't go to the Taskbar; it stays above it in a very Windows 3.11 fashion. This is against the norm for Windows applications. Changing this to multiple Taskbar items with grouping method also allows for going to a specific window when many are open. Any chance you guys are working on this for v20?
  • Hero Points: 530
Re: Minimize of windows very annoying...
« Reply #1 on: September 29, 2015, 04:24:16 PM »
Definitely would be better to have icons in the task bar. Sadly, this is far from a simple change due to how various UI elements need to stay on top of each other (need access to the one menu bar too).
