Author Topic: Can't select all (ctrl-A) in some dialog windows  (Read 3363 times)
TKasparek
  • Hero Points: 28
« on: September 29, 2015, 03:25:28 pm »
In:
list-buffers
activate-files-project
activate-files-workspace
you can't do a select-all like you could in v19. I use this often to clean up my open files.
On another note, v19/v20 would allow you to hit ctrl-A after opening the list-buffers dialog and would put a non-printable character in the filter and search on it...
  • Hero Points: 467
Re: Can't select all (ctrl-A) in some dialog windows
« Reply #1 on: September 29, 2015, 04:15:46 pm »
What emulation are you using? It seems to work in v19 and v20 in CUA emulation. In SlickEdit emulation (what I use), it doesn't work in either.
  • Hero Points: 467
« Reply #2 on: September 29, 2015, 06:11:53 pm »
In any case, we will fix this in a future beta. Thanks for noticing.
TKasparek
  • Hero Points: 28
« Reply #3 on: September 29, 2015, 07:27:35 pm »
I'm using CUA emulation. I'll try with default options in a bit...
  • Hero Points: 467
« Reply #4 on: September 29, 2015, 07:47:38 pm »
If you rebound Ctrl+A in CUA emulation, then it would have broken it for the text box and combo box. In any case, this will be changed. Ctrl+A will almost be hardwired to select-all.
mkatz
« Reply #5 on: October 02, 2015, 03:33:21 pm »
I am experiencing this issue in Brief emulation.
The following CUA selection keys do not work in the Brief ALT-B (list_buffers) window.
Alt-A
CTRL Up Arrow
CTRL Down Arrow
CTRL SHIFT Home
CTRL SHIFT End
CTRL HOME (HOME goes to top of list)
CTRL END (END goes to bottom of list)
  • Hero Points: 141
« Reply #6 on: October 02, 2015, 04:56:37 pm »
We'll look into this.
  • Hero Points: 467
« Reply #7 on: October 07, 2015, 12:55:10 am »
This key assignments will be added for the next beta. Thanks for the good attention to detail.
  • Hero Points: 291
« Reply #8 on: October 07, 2015, 07:31:16 am »
Great - one more patch to drop :) I wasn't keen enough to request that in the past  :-[
Thanks, HS2
