Author Topic: Visual Studio project has no files  (Read 2132 times)
arog
  • Hero Points: 3
« on: October 05, 2015, 10:47:03 pm »
This might be similar to a couple of other bugs reported.  If I open a workspace from a visual studio SLN file (created by unity), the Slickedit doesn't seem to see the files added to any of the projects.  The same workspace works fine in v19.0.2.5 + hotfixes
I've attached a tiny project.  Opening this in v20, select project properties and there won't be any files in the project window, doing a Find all in files <Workspace> will return "No files were found to look in", etc.
OSX 10.9.5, Slickedit 20.0.04, project is generated from Unity 5.2.1p2 if that matters.
Let me know if you need any additional info.
Thanks!
Re: Visual Studio project has no files
« Reply #1 on: October 06, 2015, 12:54:14 pm »
Thanks for the report.   This has been reported and will be fixed in the next beta release.
