Author Topic: SE crashes on 'New Updates' behind corporate proxy server  (Read 3755 times)
DavidA
« on: October 06, 2015, 08:35:10 am »
Hi
This bug applies to SlickEdit Pro 2015 (v20.0.0.4 64-bit) on Windows 8.1 64-bit.
I work behind a corporate proxy server. I have set the proxy server details correctly in Product Updates > Options.
When I invoke Product Updates > New Updates, SlickEdit crashes (Windows reports that SE has stopped working).
This is the same bug as I reported in:
https://community.slickedit.com/index.php/topic,11002.msg46468.html#msg46468
I had hoped that it would be fixed by now.  :(
Best regards
David
Re: SE crashes on 'New Updates' behind corporate proxy server
« Reply #1 on: October 06, 2015, 07:14:19 pm »
Thanks for the report.  This should be fixed for next beta release.
DavidA
« Reply #2 on: October 29, 2015, 08:58:36 am »
I've installed Beta 3 and product updates (behind a proxy server) are still not working for me  :(
The proxy is set correctly in Help > Product updates > Options
but:
Help > Product updates > New updates
gives:
SlickEdit Pro
Error retrieving updates.
MANIFEST: URL status condition -
OK
However, SE no longer crashes.
DavidA
« Reply #3 on: November 02, 2015, 09:06:08 am »
New Updates is still failing in SlickEdit 2015 v20 release candidate 4:
SlickEdit Pro
OK
Any chance of a fix please?
  • Hero Points: 468
« Reply #4 on: November 02, 2015, 01:53:52 pm »
It's unlikely we will be able to fix this. Sorry
DavidA
« Reply #5 on: November 02, 2015, 02:03:33 pm »
It seems a pity to admit defeat on this issue.  I use several other editors and IDE's and they cope happily with a proxy server.  Is it really so difficult to fix?
