Author Topic: install complete window nearly off screen  (Read 1865 times)
TKasparek
  • Hero Points: 28
« on: October 07, 2015, 01:15:57 am »
I noticed this with Beta 1 and figured it was a fluke but it happened again with install of Beta 2. After the install is complete the final window of the installer shoots way to the left top and almost completely off the viewable area of my desktop. There was just enough room to grab under the X to pull it back.
I have a 3 monitor config with the center one as the primary.
Win7 x64
Tim Kemp
  • Hero Points: 91
Re: install complete window nearly off screen
« Reply #1 on: October 07, 2015, 11:02:19 am »
I have the same setup as you, Windows 7, three monitors. I didn't have that issue with either install.
