Author Topic: Beta 2 on OS X: Prompt for ZIP extension during export is awkward  (Read 1788 times)
jkwuc89
  • Hero Points: 6
Reproduction steps are below. I am currently using OS X Yosemite.
  • Open Preferences
  • Click on Export/Import Options
  • Click on Export All Options...
  • Click on ... button to change the export package destination. Notice that the filename next to Save As: does not have the .zip extension
  • Change the filename and change the directory where the package will be saved and then, click on Save. The prompt indicates that the standard extension is ..zip (see attached screen shot). This should probably be .zip
Sandra
  • Hero Points: 36
Re: Beta 2 on OS X: Prompt for ZIP extension during export is awkward
« Reply #1 on: October 08, 2015, 01:50:46 pm »
Good find.  This will be fixed in the next beta drop.
