Author Topic: Right click menu changes not migrating to new version  (Read 2104 times)
jorick
  • Hero Points: 16
« on: October 08, 2015, 06:36:14 pm »
When I right click on a word, a menu pops up that allows me to do a quick search on the word.  I've modified the menu so that when I'm close to the bottom of the window and the menu pops up with the cursor pointing at the bottom line, I have a second Quick Search defined so I don't have to run the mouse up to the top of the menu to do the quick search.
The menu changes didn't get copied to v20 Beta during the install.  Granted a one line change probably isn't a big deal, but there may be others with massive menu changes that will spend a lot of time redoing their menu.
Sandra
  • Hero Points: 36
Re: Right click menu changes not migrating to new version
« Reply #1 on: October 08, 2015, 08:33:42 pm »
Is there a file called userMenus.xml in your v19.0.2 config?  If so, could you post it here?
jorick
  • Hero Points: 16
« Reply #2 on: October 08, 2015, 09:31:07 pm »
Attached.
Sandra
  • Hero Points: 36
« Reply #3 on: October 09, 2015, 02:12:19 pm »
Hrm.  Could you take a screenshot of the menu as it appears in 19.0.2?
jorick
  • Hero Points: 16
« Reply #4 on: October 09, 2015, 02:53:04 pm »
Attached.
Sandra
  • Hero Points: 36
« Reply #5 on: October 09, 2015, 03:19:49 pm »
I've got a fix for this.  The fix won't help those upgrading to v20, but it'll solve the issue going forward from there.  Luckily, it was a really specific bug - it only showed up when duplicating the first menu item.  Great catch!
jorick
  • Hero Points: 16
« Reply #6 on: October 09, 2015, 03:40:58 pm »
Strange but v19 used to have an "Edit This Menu" item in the popup but I don't see it anymore.  And v20 doesn't have it either.  Did it get taken out in one of the v19 updates?
Tim Kemp
  • Hero Points: 91
« Reply #7 on: October 09, 2015, 03:42:56 pm »
Edit This Menu shows up at the bottom of my pop-up menu in v20
Sandra
  • Hero Points: 36
« Reply #8 on: October 09, 2015, 03:43:55 pm »
It's gone in v20 because it went missing in your v19 config, and that change was upgraded.  You can reset a menu by going to Macro > Menus.  The one you want specifically is _ext_menu_default.
