Author Topic: Slick went to full screen & stayed there.  (Read 1457 times)
jimlangrunner
  • Hero Points: 31
« on: October 09, 2015, 03:37:56 pm »
I'm not sure if this is related or not, and I cannot reproduce, so this is more of a note than a complaint.
I was using Beta 1 and did _something_ to cause Slick to go full-screen.  No title bar, no borders, nothing but the menu bar. I could open dialogs with little problem, and all keyboard shortcuts worked.  I searched help for some way to get back to a normal window to no avail.
So I blew away my config directory & restarted - everything back to normal.
Tim Kemp
  • Hero Points: 91
Re: Slick went to full screen & stayed there.
« Reply #1 on: October 09, 2015, 03:39:37 pm »
Shift + Ctrl + Z maybe?
I guess that's zoom_window()
Do it again to get rid of it.
jimlangrunner
  • Hero Points: 31
« Reply #2 on: October 09, 2015, 03:43:31 pm »
Tim,
Thanks - but that's not it.  All zoom-window gets me is getting rid of the file tabs.  What I experienced filled the entire screen (and I didn't note any tab or absence thereof.)
Tim Kemp
  • Hero Points: 91
« Reply #3 on: October 09, 2015, 03:46:16 pm »
I usually have SE full screen, so it sounded likely. I hope you figure it out. I usually get those sorts of things happening to me after my cat walks across the keyboard.
