Author Topic: Block insert typing strange  (Read 2510 times)
jorick
  • Hero Points: 17
« on: October 09, 2015, 09:52:28 PM »
In the C language, I want to change the following lines in a structure
   GPIO_Pin_t stX1Pin;                 //!< X1 line
   GPIO_Pin_t stX2Pin;                 //!< X2 line
to
   GPIO_Pin_t stX1Line;                 //!< X1 line
   GPIO_Pin_t stX2Line;                 //!< X2 line
So I block select the words "Pin" and type an L, and I get:
   GPIO_Pin_t stX1; L                //!< X1 line
   GPIO_Pin_t stX2; L                //!< X2 line
So the L is being inserted in the wrong place.
  • Hero Points: 531
Re: Block insert typing strange
« Reply #1 on: October 09, 2015, 11:07:07 PM »
This will be fixed in the next beta
