Author Topic: SlickEdit Eclipse plugin error  (Read 7465 times)
kilonzi
« on: October 13, 2015, 07:11:18 pm »
Just recently, I started getting the following error in my slickedit plugin for eclipse. Does anyone have any thoughts about how to debug this error. I can see the class in the jar file but I am not sure why eclipse is having a hard time loading it. My current suspicions is that maybe the jvm is throwing an error trying to load the class but I can't figure out how to prove or disprove that theory.
org.eclipse.core.runtime.CoreException: Plug-in com.slickedit.eclipse.plugin was unable to load class com.slickedit.swt.PluginEditorPart.
   at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
   at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:176)
   at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
   at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
   at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
   at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:294)
   at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
   at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:289)
   at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
   at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:349)
   at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:265)
   at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:63)
   at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:303)
   at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
   at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
   at java.lang.reflect.Method.invoke(Method.java:497)
   at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
   at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:888)
   at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:869)
   at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:120)
   at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:337)
   at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:258)
   at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
   at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
   at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
   at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
   at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:127)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:983)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:662)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:766)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:737)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:731)
   at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:715)
   at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1246)
   at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer.postProcess(LazyStackRenderer.java:103)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:678)
   at org.eclipse.e4.ui.workbench.renderers.swt.SWTPartRenderer.processContents(SWTPartRenderer.java:69)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:674)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$6.run(PartRenderingEngine.java:547)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:531)
   at org.eclipse.e4.ui.workbench.renderers.swt.ElementReferenceRenderer.createWidget(ElementReferenceRenderer.java:69)
   at org.eclipse.e4.ui.workbench.renderers.swt.SashRenderer.processContents(SashRenderer.java:185)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveRenderer.processContents(PerspectiveRenderer.java:49)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.showTab(PerspectiveStackRenderer.java:103)
   at org.eclipse.e4.ui.workbench.renderers.swt.PerspectiveStackRenderer.postProcess(PerspectiveStackRenderer.java:77)
   at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.processContents(WBWRenderer.java:663)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1078)
   at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
   at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
   at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
   at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
   at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
   at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
   at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
   at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
   at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
   at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
   at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
   at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
   at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle com.slickedit.eclipse.plugin (966).
   at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
   at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:531)
   at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:324)
   at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:320)
   at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:395)
   at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:345)
   at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:337)
   at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
   at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
   at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:568)
   at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
   ... 132 more
Caused by: org.osgi.framework.BundleException: Error loading bundle activator.
   at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
   at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:936)
   at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:319)
   at org.eclipse.osgi.container.Module.doStart(Module.java:571)
   at org.eclipse.osgi.container.Module.start(Module.java:439)
   at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:454)
   at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
   ... 142 more
Caused by: java.lang.ClassNotFoundException: com.slickedit.eclipse.SlickEditPlugin cannot be found by com.slickedit.eclipse.plugin_3.7.1
   at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:382)
   at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:754)
   at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:706)
   ... 148 more
