I'm running v20b3:
SlickEdit Pro 2015 (v20.0.0.5 64-bit)
Serial number: FE35645_BETA
License type: Beta License
License expiration: 2015-11-21 03:19:00
License file: /home/bjkurlex/slickedit/bin/slickedit.lic
Build Date: October 12, 2015
Emulation: Vim
OS: Linux
OS Version: SUSE Linux Enterprise Server 11 (x86_64)
Kernel Level: 2.6.27.19-5-default
Build Version: #1 SMP 2009-02-28 04:40:21 +0100
X Server Vendor: The Cygwin/X Project
Memory: 97% Load, 10901MB/11173MB Virtual
Shell Information: /home/bjkurlex/slickedit/bin/secsh -i
Screen Size: 1920 x 1200, 1680 x 1050, 1600 x 900
Project Type: (Other)
Language: .c (C/C++)
Encoding: Automatic
Installation Directory: /home/bjkurlex/slickedit/
Configuration Directory: /home/bjkurlex/.slickedit/20.0.0/
Spill File: /home/bjkurlex/tmp/$slk.bjkurlex.19238
(Cygwin, Multiple Windows) on Windows 7.
I double clicked the title so that it went full screen. However, I'm seeing lots of jerky refreshes (entire window appears to draw a few pixels down and then redraw where it belongs) when using colon commands (the first ':' is all that is needed to reproduce this). It appears to reproduce 3 or 4 times and then finally behave (e.g., : <esc> : <esc> : <esc> ...) when it behaves, all I need to do is move the cursor in my window and it will start acting up again with the next colon command.
It doesn't appear to do it when in a normal window mode, only when the window is full screen.
